How long does it take for a Tailgater Pro to start up?
Satellite TV anywhere. That’s the promise of the KING Tailgater Pro. For one low price, you get a portable satellite TV system that works pretty much anywhere there’s a view of the southern sky. It’s custom designed to work perfectly with a DISH Wally. Just hook up one cable and go. The Tailgater does all the hard work, aiming itself to receive DISH’s Western Arc satellites perfectly.
But how long does it take?​
Of course, when you get started, you’ll want to start watching TV instantly. But, I want to set fair expectations. This device has a lot of hard work to do before it starts showing live TV. And that takes time.
In general, if you’re taking it out of the box for the first time and you don’t have an activated receiver, you should give yourself an hour or more minutes. This will include the time you spend getting the receiver activated, the time it spends downloading software, and that sort of thing. You’ll get the fastest results by calling 888-233-7563 and letting the experts at Signal Connect activate the receiver for you.
If you’re taking an activated receiver from home and connecting it to the Tailgater, you should still expect about 20 minutes’ wait while the Tailgater self-aims and confirms everything it needs. The final check process takes 5-6 minutes by itself.
If you’re turning on the device after it’s already perfectly aimed, it shouldn’t take more than just a few minutes to confirm everything. It’s essentially the same amount of time you would expect to spend if you powered up the receiver at home.
Is there a way to speed this up?​
For the most part there’s only one way to make the whole process go faster. Make sure the Tailgater is on a level surface, as level as possible. Then make sure the handle is facing north. This will orient the device properly, which saves time as it’s going through its internal self tests. It may only save you 1-2 minutes, but hey every little bit counts.
More questions? call the RV Experts!​
Signal Connect has 20 years’ experience with the RV community. No one has done more satellite activations than we have for RV and marine customers. We’re the leaders in the industry. Why would you work with anyone else? Get the customer service you deserve. Call Signal Connect at 888-233-7563. We’re here during East Coast business hours. If it’s after hours, fill out the form below. We’ll get right back to you!
The post How long does it take for a Tailgater Pro to start up? appeared first on The Solid Signal Blog.
Continue reading...
STREAMING SATURDAY: The dog days are over, but where’s the programming?
Can you run two TVs from one HDMI2COAX adapter?
