Frequently Asked Questions about OTA Scanning Fucntion
- How does OTA Scanning Works?
- What happens if my local station does not provide PSIP (Channel Number, MPEG Service Number and Short Name) data?
- The OTA Scanning Function added new channels but I have no PG information. What should I do?
- How can I save my OTA channels that are found?
- If you lose power or unplug the stb, would you lose your mapping?
OTA Scanning function in software 6.00 and later has two screens. One screen is identical to the Aim Satellite Dish screen (sorry I don't have an actual picture but I am working on it). It states (1) that local will be locked at 80 and (2) to allow for rain fade the strength must be at least at 85.
Aim Satellite Dish
http://www.satelliteguys.us/attachment.php?attachmentid=1359
OTA Scan Screen
http://www.satelliteguys.us/attachment.php?attachmentid=1361
1 - Some of you have asked why does the OTA scan has to lock at 80? How about OTA channels that exhibit signal strength lower than 80? does this means I am out of luck in receiving these?
Based on what I was able to find out. The 80 and 85 number on the Aim Satellite Dish (same for OTA) are based completely on a different scale than what the OTA signal quality or strength was based on software version 5.68.
This is how the process works (this comes from Motorola):
The way this works is that we take a sample of 8 lock status readings from the demod and then calculate a value based upon a combination of how many readings had "Signal Lock" status and the resulting SNR if a good quality lock was achieved.
1) A signal level reading of less than or equal to 80 indicates that the signal was not "locked" on any of the 8 sample readings we took. The actual value of the number in that case is based upon a scaled AGC value (i.e. it indicates how much power is present in that RF band). If this number is below 80 it is unlikely that you will get video unless something changed in between when you took the reading and when you attempt to look at video.
2) A signal level reading between 81 and 84 indicates that the signal was "locked" between 1 and 7 times when we took the readings. You can probably get a picture in the higher end of this range but it will likely have macroblock errors in the active video. It will take a fair amount of luck to decompress any video at all in the low 80's.
3) A signal level reading of 85 or greater means that it was "locked" all 8 times and the higher the number the better the SNR. Each tick on the scale after you are above 85 roughly cooresponds to a 1 dB increase in SNR.
Also - In order for a channel to get saved in the map, PSIP must be available in the stream with at least the following three fields present: Channel Number, MPEG Service Number and Short Name. You may sometimes see the scanning process pause when it hits a signal and then not actually save the channel. What is happening is that the scanning process is paused to allow a reasonable amount of time for PSIP data to come in even for low quality signal level. If no channel is saved after one of those pauses, it is likely because it failed to obtain the required data from the stream.
2 - What happens if my local station does not provide PSIP (Channel Number, MPEG Service Number and Short Name) data? You can try one of these three things.
a) - Speak to your station engineers and ask that the PSIP data (Channel Number, MPEG Service Number and Short Name) be passed to their stream.
or
b) - Request that your channels be mapped. If you haven't done so, send me an email to Sean_Mota@satelliteguys.us with your full address and which channels are not mapped in your PG. This process will only be able to map channels within your DMA.
or
c) - There is work in progress right now to create a super DMA map that will provide mapping (without OTA Scanning software) to more than one DMA. This is in the works and it will not be done till October/November. (this of course implies waiting for this mapping to be created)
3 - The OTA Scanning Function added new channels but I have no PG information. What should I do?
The PG information comes from the Satellite. The data itself needs to be entered by Tribune. Send an email to Sean_Mota@satelliteguys.us and I will make the request for you.
4 - How can I save my OTA channels that are found?
"found and added" OTA channel are cumulative. So this means that it will not delete your mapping. Now, here is the deal with version 6.0. There's a bug in it that does not allow it to keep the channels found. As I told you before this version 6.0 is beta. A solution has been found already.
5 - If you lose power or unplug the stb, would you lose your mapping? No.
