How did you upgrade the hard drive?
What type of drive?
My 87 year old neighbor has been bugging me about running out of space
On the HR54 or the 24's?
Of course you can add an external eSATA drive, but I don't like having to worry about finding a place to stick the EHDD, so I just crack open the receivers and replace the HDD.
The 44 and 54 can 'see' up to a 8TB drive
24's can't 'see' over 2TB
The cover on the 54 is SUPER easy to get off, just flip it over, there are four slots, just about big as the end of a paper clip. I took a paper clip and stretched it out, took one of the curved ends and stick down in that slot, it will release a clip and you can begin to pull the cover off the top of the 54.
The 24s, there are four slots on the sides, take a flathead scewdriver and pull back in those tabs, you'll hear a click where the clip releases, I cut up an old plastic card, kind of like a credit card, ease that sliver of that card in between the cover and the clip, do it on all four sides, and pull the cover off, then you'll be able to take the HDD out.
The HR24-200 will only accept a very thin platter, so you have to basically find one that is the right thickness or use an eSATA enclosure with it. The 500s will work with about any thickness.
I bought WD Black drives, they're a little more expensive, but they're high performance. Probably overkill, but I read where a good high performance HDD could help improve the performance of the HR receivers.
Seems to have made the 24's quite snappy for them.
Of course it could be the placebo effect of me spending the extra bucks.
