How to find your True South Satellite.
Your True South satellite is at the same orbital location in space as your longditude here on Earth, I will use Minneapolis MN. as an example, the longditude here is 93 deg.W
lf you check the below link you will see the satellite at that orbital position is IA6 (Telstar 6)
http://www.lyngsat.com/america.html
So using a compass your true south satellite will be at 180 deg. or South
Then the Earths magnetic pull must then be taken into account, again if you refer to the below link it will give you a rough magnetic deviation angle for your location, here in Minneapolis the magnetic deviation is around -2 deg, so the reading on the compass should now be 178 deg. W for my true south satellite IA6 (T6)
http://www.geo-orbit.org/sizepgs/magmapsp.html
