So, how many people here have installed their own AT9 dish and pointed it successfully? What was your experience? How long did it take? How much more difficult is it to point when compared to the Phase III dishes? Thanks guys.
Thanks for your response.frankyboy4 said:Paulie,
I just did a custom AT-9 install for my home over the weekend. I had originally had a DTV installer come out, and tell me that they couldn't do the install because where the Dish had to be mounted they couldn;t do with the hardware that was provided.
My origial 3LNB setup was on a custom arm I had made years ago.
I called DTV and told them my problem and they gave me a rebate equal to the cost of the dish, so I bought one online. Going by where the DTV installed said I needed the dish to be I had a 12" straight piece of exhaust tubing cut at the local muffler shop that I used for my Dish arm. I set the tilt and the elavation by the install screen from the reciever and eye balled the azimuth based upon my existing 3LNB dish.
When I put a reciever on the new dish I was in the 80's for most transponders.
All in all I found it muhc quicker and easier then the 3 LNB setup. I did this during dusk.
So the next day I fine tuned it using the reciever and got most transponders in the high 80's to 90's.
If you are putting this on the roof make sure the center of the mounting bracket is over a roof joist so that your lag bolts really have a good grip. I have a total of 8 lag bolts in my setup with 4 on top and 4 on the bottom. As far as I can tell it isn't going to move anywhere.
good luck
Franky C.
Thanks.dfergie said:This link may help you.
Sounds great. I'm encourraged that I haven't heard any horror stories yet on this. I just need to get that transponder list and I should be good. Once again, thanks a lot.frankyboy4 said:The settings were not all the same but once I did the fine tuning, I did have good signal levels acorss all 5 sateliites. Also make sure you know what transponders you should be seeing on the 99 and 103 birds, it will depend on where you live as to what transponders you will see signal on.
I found this to be the easiest setup I have done, and I have done all of my installs dish installs.
There is another thread that shows the transponders that will be seen based on the DMA market.
Franky C.
I have a Phase III arm mounted on a Dish 500 Pan and have been unable to find more than just Sat A (experimenting) I will tackle the at9 when my locals come up later this year... probablly a 7 or an 8PaulieORF said:Thanks.
That video is actually the reason I'm posting this question. The video makes it seem like pointing this dish without the $125 signal meter could be quite difficult. Is getting signal from all 5 sats as difficult as this video makes it seem? Let's say if getting your signal on the Phase III dish was a 3 on a scale of 1 to 10 for difficulty, how would you rate doing the same with the AT9?
PaulieORF said:So, how many people here have installed their own AT9 dish and pointed it successfully? What was your experience? How long did it take? How much more difficult is it to point when compared to the Phase III dishes? Thanks guys.
I don't have a mater, but here's my plan: Slingbox connected to the H20 my laptop on the roof, there's my signal meter.mechman said:Did mine a week ago and had zero issues. I have a meter though and I'm in the mid 90s.
mechman
Sounds like a plan!!PaulieORF said:I don't have a mater, but here's my plan: Slingbox connected to the H20 my laptop on the roof, there's my signal meter.
