OK, I'm with primetimeguy with everything he said up until this last post. No, no, no, a thousand times no! The 3rd prong is a protective ground and in general removing it will only increase your chances of electrocution! That's why it's there. Don't bypass it unless you actually take that little green wire and screw it vigorously to another well-grounded spot. The real ground is one of the 2 vertical (not D-shaped) prongs on the plug. I have several times seen the true ground come loose, and some equipment will quit working (as it should), while other equipment starts using the protective ground! Were you to disconnect the protective ground in such a situation, in all likelihood the chassis of your equipment would be hot.
