I have a lot of experience with long distance TV reception (I used to install antennas as a side business) and I find TitanTV to be inconsistent. They range from overly optimistic to overly pessimistic, depending on location.
If you want to receive stations 50 miles away
reliably, a small antenna will not work unless you sit on a mountain top. I recommend (and use) a Winegard HD9095P (
http://www.winegard.com/offair/pdf/hd9095p.pdf) UHF-only antenna. It is very directional, has high forward gain, and is very well built. It has a built-in VHF coupler (all connectors are 75 ohm coax) which allows a separate VHF antenna to be pointed in a different direction.
Unless you want to try pick up Channel 3 in Lewiston, use either a Winegard YA-6713 (
http://www.winegard.com/offair/pdf/ya-6713.pdf) or YA-1713 (
http://www.winegard.com/offair/pdf/ya-1713.pdf). Both are designed only for channels 7-13 (VHF-hi), which makes them much smaller than an all VHF model.
You will also need a low-noise preamp. Two possible choices are the Winegard AP-4700 and the AP-8700 (
http://www.winegard.com/offair/pdf/Chart29.pdf). The AP-4700 is UHF-only (passes VHF) and the AP-7800 is VHF/UHF. If you live very close to an FM transmitter, there is the risk of interference if you use the AP-8700 (Radio Shack sells an FM trap).
If you want to try to pick up more distant stations (for more money), Channel Master makes the excellent Titan series pre-amp (
http://www.channelmaster.com/Pages/TVS/TitanAmp.htm) that a friend of mine is quite pleased with (he's 50 miles from the closest transmitter). Model 7775 is UHF-only, but it
will not pass VHF. Model 7777 is UHF/VHF and offers the option of separate UHF and VHF inputs (be careful of potential overload from local stations). If you try the 7777 and VHF overloads, you can buy 6-db pads at Radio Shack for the VHF input. These pre-amps are specifically designed for Fringe reception.
A reputable mail-order source I have used for many years is Warren Electronics (
http://www.warrenelectronics.com/), if you can't find these locally. You could also try
http://shopping.yahoo.com and search by make/model (i.e. "Winegard AP-4700"), where you may, or may not find a better price.
If you have more questions, you can reach me at
markserr@att.net
