Perhaps, but I would be a bit surprised to be honest. It isn't unheard of for processors to cause issues, but it is pretty rare these days.I think that you have identified the culprit.
19Mbps ain't much bandwidth for HDMI cable. Hope he meant 18GHz.
OP has spent a metric ton of cash on a Kaleidescape, OPPO UHD player, and other high-end gear, and on professionals to install and calibrate it. Sounds like he just might not be satisfied with consumer-level video quality. Dish HD is good enough for most people, but it's nowhere near what you'll get from a full-bitrate Blu-Ray or professional-studio-type sources.
It has been over week since I had a new dish installed and I still got one concern on the HD signal and quality on the locals. The HD quality on the locals depending on the station too is very sharp and pixel and the face is either sharp mix with blurness. I called Dish and told them about this and an overseas staff told me my signal is fine and they sent out another signal to my receiver. But, I am still getting this sharp/blurness. And, I am also once in a while getting a 1-2 second signal flash pending on the channel. The other stations from channel 101 and up are fine. Any suggestion??
While HelenDee’s profile shows her from Los Angeles, she said in another thread that she lives 20 miles from San Francisco. There is a long way in between and different spot beams involved...Well, that makes two of you in LA with PQ problems. Maybe it is localized?
No, it is just a surround sound processor. I have tried connecting the Hopper3 directly to the Sony projector via a fiber/copper hybrid cable, with the same result. Remember, I have having the same problem with two UHD displays and three HD displays.I think that you have identified the culprit.
There are no HDCP notifications. Thank you for the idea though!Check your Diagnostics. Under the History, are there any HDCP Notifications logged? I know some HD STBs will down-rez if there is an HDCP handshake issue.
Can you take a few pictures along with the guide or info showing the channel you are tuned to? It's a shot in the dark. If it as bad as you say it's like you aren't getting HD. That said, it will no way compare to your other sources. Dish is soft, and unlike what others have said I see a significant difference between OTA and Dish locals. So I do think you may just be expecting too much.There is only a setting that includes 4K and 1080p, which is where they are set in the 4K rooms, and at 1080p in the other three.
Unless the local is compressing the heck out of it, OTA should be sharper than most MVPD. Even if an MVPD is taking a direct fiber feed, they're compressing the heck out of it to get it to you.unlike what others have said I see a significant difference between OTA and Dish locals.
My point was dish is compressing the heck out of it.Unless the local is compressing the heck out of it, OTA should be sharper than most MVPD. Even if an MVPD is taking a direct fiber feed, they're compressing the heck out of it to get it to you.
Current location is San FranciscoWell, that makes two of you in LA with PQ problems. Maybe it is localized?
Your profile still says Los Angeles. You might want to update that.Current location is San Francisco
Did you save your changes?I try changing it under profile and no luck.
Yeah, I went from a 722 to a Hopper to a Hopper 3 on my 70” Sharp and it looked great all the way. Now I have a 75” Vizio and it looks really good still.Going from a 722 to a Hopper sure was an improvement on my SONY TV.
