In the rare event an installation has both satellites 119 and 61.5 on the same switch matrix, software may not download on the Hopper with Sling during initial installation. The 119 and 61.5 configuration on the same switch matrix is a rare configuration. Showroom locations and installation offices that have satellites pointing at both EA and WA for training purposes may encounter this issue when installing Hopper with Sling at the facility.
For a new Hopper with Sling installation that has both 119 and 61.5 take the following action. These steps are to be performed before powering on the Hopper with Sling:
Disconnect either the 119 or 61.5 satellite feed from the DPP switch or integrated LNBF inputPower on the Hopper with Sling and proceed with the normal installation wizard steps
After the download is complete reconnect either the 119 or 61.5 feed and run a check switch test
Proceed with installation as normal
In the event download was attempted on the Hopper with Sling while both 119 and 61.5 were connected but failed, take the following actions:
Disconnect the Hopper with Sling from power
Power on the Hopper with Sling and run a check switch test
After the check switch test, the disconnected satellite will disappear from the switch matrix and software will download normally
After the download is complete reconnect either the 119 or 61.5 feed and run a check switch testProceed with installation as normal
Thanks for the helpful post
