Recall button has changed. You don't need to press twice. Also, changing setting for multi-swap feature makes no difference.
I'm sure they'll write it off as a loss some way. Pretty stupid to spend anything on it and not use it any more than they did. I wonder if they'll stop putting "BLOCKBUSTER" on the right hand side of the Hopper faceplates?It's like DISH buying and overseeing the bankruptcy process of Blockbuster never happened..................![]()
The setting is at On,Immediate. Mine is just set to On and still requires 2 presses.Recall button has changed. You don't need to press twice. Also, changing setting for multi-swap feature makes no difference.
Sure they willI wonder if they'll stop putting "BLOCKBUSTER" on the right hand side of the Hopper faceplates?
Most likely . I see the Blockbuster name being obliterated from any new hopper design going forward.I'm sure they'll write it off as a loss some way. Pretty stupid to spend anything on it and not use it any more than they did. I wonder if they'll stop putting "BLOCKBUSTER" on the right hand side of the Hopper faceplates?
Still at the bottom between the record options and suggested shows/movie titles.On S523, did they add the satellite location (back) to the "Info" screen? I noticed it yesterday and don't think I've seen it in a while.
Sent from my HTC6535LVW using Tapatalk
That could definitely be why I didn't / don't see it very often then !The orbital location has been there all along. It only displays when you're watching live TV. It doesn't show when your watching delayed or recorded programming.
You can click the page down button( right below the aux button) to see the remaining text.I thought it was too, then it disappeared for a short time, and is back now (?).
Also, I noticed one or two (I did not check more for this purpose) program details that were 2-4 lines long and ended with "...". I thought they increased the text "field" for this a while ago and descriptions weren't being cut off. If I remember, I'll check more later.
You shouldn't have to though and it's not intuitive that you would. There is blank space for multiple more lines but they're not using it - as if it's reserved for something else.You can click the page down button( right below the aux button) to see the remaining text.
