Well, Dish Anywhere works fine. Pick one resolution and go with it. Let the user expand it to full screen, zoom, whatever.
Ok, so how do I trade out my Hopper?
If I order 2 Hoppers and 4 Joes, do I get two slings built in? If so can two mobile devices play each Sling at the same time? If only one Sling for the account, can Sling play from both Hoppers?
What is the minimum upload speed needed for Sling to work properly?
As far as networking, can I issue a recording command from one Hopper to the other? I understand they can play back each other's recordings.
Thanks in advance.
You'll have to do a Dish 'N It Up. Upgrade cost to the Hopper with Sling is $200-$300. Check with a Dirt member on here and they can help you out.
not enough to pay $100 to upgrade from a regular hopper and extend your contract. HWS is a bit faster than the regular hopper plus it has built-in wifi. The Ipad transfers should be the primary reason to change over to an HWS.What is the benefit of the Hopper with Sling if one's tablet/smartphones are Android?
Other than the offline transfers which are only available on Ipad now, it may not be worth to upgrade yet.
