Hopper not hopping
Oh goodie
Now the Hopper upstairs has 0s in the 3rd column
It cant be the receiver it has to be something else right ???
We will see what happens the next few days
Edit: just hit red button...things are back to normal...will see what happens the next few days
I have to think its an issue from the dish to the node. If I were the tech at your place I would replace the lnb, replace the cable to the node and replace the node. One thing you may be able to check, is your system grounded? If so, I would remove the ground.
Thanks I will suggest that when the tech comes back out
It sounds silly but grounding can cause intermittent problems. And the fact that you're seeing it on both hoppers makes it very hard to believe that you have 2 bad hoppers.
Switch the middle cable on the node coming from the dish with one of the two outer cables. The middle one feeds tuner three on both Hoppers. If your problem changes to another tuner, the cable to the dish has issues.
Please help me point and setup my Dish
New owner &member with a question.
