My Hopper completely lost the signal and won't even recognize the switch. I thought the Solo node went bad so I replaced that. Then the LNB. Then the cable. I checked the voltage at the cable where it enters the Solo. I have 20 VDC. So the Hopper is putting out power, the cable is good. LNB and Node were changed.
I tried a red button reset, unplug for 5 minutes. Tried a reboot and check switch with the cable disconnected. When I do the check switch test it does not go past 1 and then gives the Warning 530. The Solo Node does not even show up.
It is just not reading what is at the dish end of the cable.
My wife is on the warpath with no TV.
Any help would be greatly appreciated.
