Hello,
I have a 2 hopper 4 joey system being installed on Monday and I have a pre installation question for all of you. This way I can be ready for the installer if he gets stumped. I know this forum knows more than 90% of installers out there. Anyways, I am upgrading from the following setup: 1 vip922 (Powering 2 TV's) 1 vip622 (Powering 2 TV's) and 1 vip 722k (Powering 2 TV's). The vip 922 and 722k are connected to the spare TV's through traditional coax and Holland DPD2s. Ex The coax cable for the 2 rooms utilizing the 722 both "run" to a central distribution panel in a closet. The Satellite feed also runs to this panel. The main feed goes to room 1 and into a Holland DPD2 splitter that has one satellite output and and VHF/UHF port. The satellite feed goes to a Separator splitting it into 2 feeds for the tuners. Then I have a cable going from the home distribution TV2 output on the 722k to the VHF/UHF on the Holland DPD2. A second DPD2 on the same wires and is in the central panel and the VHF/UHF is connected to the coax cable going to the second room. This works great and the 922 is connected the same way. I am confident that there will be no issues installing a hopper and a few joeys for these 4 rooms. Now my question is how are they going to make sure my 2 upstairs rooms are connected since their setup is a little different. For the main feed, its the same as the others as a Satellite feed goes from the central panel to the 622. However, the second room is connecting directly to the 622. No connections to the VHF/UHF of the DPD2, not sharing the main coax feed. Just a cable from the 622 directly to the other TV. That room is the only one not wired to the central Panel. How are they going to get a joey to this room? I hope this makes sense and can be done. Can a Joey connect directly to a hopper? If not I may have to rethink as I need a TV feed to this room.
I know some of this info is overkill. But didn't know how else to explain.
Thanks in advance and please let me know if you may need more info.
Nate
Nate
