Hopper MOCA problems.
Under Settings/Network Setup, at the top is Network Setup where you can select from the dropdown, which ethernet connector is being used or MOCA or WIFI. I can't select MOCA on the Hopper, but I can on the Joey, today. Last time I tried it, a day or two ago, I was able to select it. In fact, earlier today I could. And on both the Hopper and Joeys (1h, 2j system) MOCA shows FAILED, but if I show the quality of MOCA by turning it on under whole home, it shows full green bars. And the Joeys work... one has E-net, the other only MOCA. Also if I look under wherever you look at the MOCA network on the hopper, it shows both hoppers linked. The SOLO is in the garage and it is 28 degrees. Quite hard to move, but I might keep an eye on it and temperature to see if that is affecting it. I know the MOCA was fine on a slightly warmer day.
