I forced the down load of 507 software and I can confirm that this bug is now squashed . It works like it used to .Maybe this software fixes the bug where you can't start a show over from the DVR menu, while it is still recording . You have to go to tv activity and start it over there.
I think the resume while still recording is working too, but I want to test it some more. This will be a miracle if fixed.I forced the down load of 507 software and I can confirm that this bug is now squashed . It works like it used to .![]()
Something weird now with the "DVR-Recordings" page on my two Hopper 3s after the U507 update
#1 Hopper 3:
#2 Hopper 3:
- On my #1 Hopper 3, the "DVR-Recordings" page shows the recordings for that Hopper
- I select my #2 Hopper 3 on the "Sources" pop-up to view its contents.
- #2 Hopper 3 is indicated on the "DVR-Recordings" page and its contents displayed.
- Exit out of DVR-Recordings page.
- Go back to DVR-Recordings page.
- #1 Hopper 3 is indicated on the "DVR-Recordings" page but the contents displayed are still from my #2 Hopper 3 (confusing).
- "Sources" pop-up indicates that my #2 Hopper 3 is still selected.
- I have to select my #1 Hopper 3 on the "Sources" pop-up to view it's contents.
Anyone else with two Hopper 3s seeing this?
- On my #2 Hopper 3, the "DVR-Recordings" page shows the recordings for that Hopper
- I select my #1 Hopper 3 on the "Sources" pop-up to view its contents.
- #1 Hopper 3 is indicated on the "DVR-Recordings" page and its contents displayed.
- #2 Hopper 3 is indicated on the "DVR-Recordings" page but the contents displayed are still from my #1 Hopper 3 (confusing).
- "Sources" pop-up indicates that my #1 Hopper 3 is still selected.
- I have to select my #2 Hopper 3 on the "Sources" pop-up to view it's contents.
Seeing same thing for me too on my two H3s..Something weird now with the "DVR-Recordings" page on my two Hopper 3s after the U507 update
#1 Hopper 3:
#2 Hopper 3:
Yes, seeing that here too. It's been this way for the last couple of updates. I reported it when I first noticed it but the more reports they get the better chance that they'll fix it.![]()
Started with U506 for me.Didn't have the problem with U503. Must have started with U504.
I think the pause while recording and then resume after the recording is complete issue is fixed now. Tested it twice. I am so happy happy. Anyone else notice if it is fixed too?I think the resume while still recording is working too, but I want to test it some more. This will be a miracle if fixed.
Yep, I was noticing that too after U506.Not sure about while recording but even already recorded material wouldn't resume where left off on one of the recent updates. Its working normal now.
Heads up - after my U507 upgrade serial ports didn't work and I had flashbacks of a year or so ago when an upgrade trashed the MBR on two EHDs. A pull of the power plug, count to 20 and both drives now recognized as being plugged in and unplugged.
It's fixed now in the 507 software. I posted earlier in the thread that I tested it this morning and it works like it ought to now.I don't know how that isn't fixed on H3 yet. My HWS hasn't had that problem for a couple months now.
I think you mean the USB ports. My external hard drives and my USB OTA tuners all had no problems after upgrading to U507.
Now if I could buy a modern laptop with a 9-pin RS-232 port on it my life would be easier. Those USB-to-serial adapters just suck.RS-232 is alive and well.
The vast majority of Cisco hardware more than 2 years old require a serial port to perform initial configuration and most troubleshooting.
