When you are talking about calculate disc usage, are you talking about the Disc usage % not changing until a few days later? In my case, I rebooted originally using the Restart Hopper in the menu when I had the problem still yesterday but a Red Button Reset yesterday fixed it. I can't offload to an EHD as it got filled up when everyone was away on a trip. Too bad we can't record to EHD instead but in my case, the disc full message popping up every 5 seconds is annoying even when it isn't recording an event when the disc usage is already back at 70% and it's still not recording events as it still thinks it's out of space.
Yeah, I was talking about usage % not changing.
This is why I've always been fussy about disc mgmt. on my PC because you never know
what will happen when it hits the limits. For a different user it might be a different problem.
I don't know but maybe you accidentally found a glitch in the software.
Dish doesn't give us many options but here they are:
1. RBR
2, Power cord reset
3. Partial reset from the "Tools" menu
4. Factory default reset from the same menu.
5. Call tech support
I doubt if support has encountered this problem but I guess it's worth a shot.
I assume you did the first two.
If it were me getting nagged with full disc messages I would go straight to the
brute force option 4. This apparently clears the Hopper out and makes it look
like it did when it came out of the box so first I would write down all my timers
in case the remotes also get cleared.
But I'm not you so if you or someone there doesn't want to lose the recordings
try to hopefully find another way.
I believe the partial reset doesn't delete the recordings but don't know what it
actually does. A few people here have done the partial so hopefully they
will chime in on that.
Good luck. Sorry this happened to you.
