On my old 722, I had the "Inactivity" option on the receiver set to 4-hours -- so, when I turned the TV off, the receiver would stay on -- therefore, if I came back and turned the TV back on a half-hour later the receiver was still on and I could rewind the channel it was on.
With the Hopper 3, I also have the "Inactivity" option set to four hours -- however, the receiver shuts itself off shortly after I turn the TV off. It does this regardless of whether I use my 52.0 remote, or turn the TV off manually with the button on the TV.
Not very convenient when, for example, you're watching a show -- you turn the TV off because someone comes to the door, and then when they leave you turn the TV back on and can't rewind the show you were watching because the receiver turned off with the TV.
It's also frustrating when I set an AutoTune timer: I set the timer for Channel 6 at 9am ... I turn the TV on at 9:05 and Channel 6 is the first channel that comes on the screen after pressing the select" button, but I can't rewind the show because the receiver had just turned on.
Any suggestions?
Any suggestions?
