Hi all,
Long time 922/722 user that just upgraded to a Hopper 3 yesterday. I have some questions I hope will be simple, even though I have had trouble finding answers when I searched here and elsewhere on the Internet.
Phillip
- My configuration is one Hopper 3 and three Joey's. Each came with one remote. I have configured two iPhones to also control the Hopper and I have ordered three additional remotes (We like to have them scattered all over the main room.). Is there a limit to the number of remotes that can be paired to a Hopper 3? What about a Joey?
- I moved a 1TB external drive over from one of the old boxes. Somewhere I read when you connect an external drive you lose the internal drive. Is this true or not? What is the maximum capacity of an external HDD? Any reason you cannot use an SSD?
- When I went to bed last night The Weather Channel channel was on and I just turned the TV off. Just like I previously did with the 922. When I woke up this morning and turned the TV on it said no signal. Sure enough, no lights on the Hopper, so I pushed the Hopper power button on the remote. A green LED came on, but still no signal. After 5-10 minutes I tried turning both off and back on again with the same (no) result. I then did a red button hard reset on the Hopper and all is well. When I went to Dish and did a chat: A) It was clear they were working off a script., B) They had no clue., C) They said to see if it does it tomorrow and if so they would schedule having it replaced. I read lots of comments about this same problem all over, but nobody has posted a solution that I have seen. Does anybody here have any idea?
- How do you configure the guide to only show your HD channels. In other words, the ones you are subscribed to and only the HD offerings. This was easy using a drop down list on the 922, but I can't seem to figure it out with the Hopper.
Phillip
