You wouldn't want anything I'd cookThat must make it hard for you to use the oven to cook anything.![]()
All Hopper/Wallys use the same lousy OTA adapters.Does the Hopper Duo take the same ota adapter
i got the OTA adapter for my Hopper Duo it will only pick up 7 channels i got 37 hooked to my tv does anybody else have a problem picking up channels
You will need to improve your TV antenna reception.that explained it i only get 50 to 60%
Even stations that read that strong are not always reliably picked up by the scan. I have a couple of channels that consistently read 100%, yet they are not always found on the scan every time, nor are the few channels that read around 80% or slightly less. It always takes several scans on my Wally before I can get all of the stations to come in at the same time. I honestly think that this is partly a software problem, with the software automatically rejecting any stations that it "thinks" are reading too low, instead of listing everything it finds and letting us make that decision.The dual tuner is not very sensitive. Signal "strength" needs to be above 75-80% reading on the Hopper for OTA channels to work reliably.
well it has completely quit working i have scanned 10 are 15 times and it finds nothing i am sending it back to Amazon
will a Dish network usb single dongle work?
Any chance I can use this Hauppage 955Q I have sitting here, or have they purposely made everything proprietary?
At the very least, the scan seems to work better with the single OTA tuner, for whatever reason. One possible work-around is to use the single OTA tuner to scan all of the channels it can find into the Wally, and then switch to the dual-tuner. (There is no need to re-scan again after swapping OTA adapters. The channels from the single tuner's scan will still be listed.)Does the Dish Single OTA tuner have better reception than the Dual OTA tuner? My TiVoHD gets 76 OTA channels but the Wally Dual OTA tuner only gets 43 channels. Both are connected to a Winegard SensarPro.
If you have strong signals the new dual OTA tuner will work
My dual quit working, I swapped back to my single OTA tuner. I just wish they would fix the dropped audio on the recordings. If I watch it live the audio is fine.
