Home Transponders & Minimum & Average Thresholds
They are:
119
14, 15, 16, 21
110
14, 15, 16, 21
129
19, 20, 29, 30
Here, minimums for 119/110 basically all 60-64 except 119-14 which is 54. Minimum for 129 is 39.
A lot of receivers will probably not show you those transponder signals for 129, you would have to use sat meter. You can also check trans 21, try to get it between 48-55 for equivalent signal value for home trans.
Yep TP 21 on 129 is QPSK so it should pull in on the older receivers. Personally I'd aim for at least high 60s on 110/119 and at least 45 on most of the 129 TPs. TP 21 on 129 should be at least mid-high 60s.
Sent from my iPhone 4S using Forum Runner
Readings
  • Just checked my numbers. 129 - 41to 52, 110 46 to 53, 119 71 to 81. Which way should I adjust my dish to max these numbers?
Looks like your skew is off. Make sure your mast is plumb and check your skew.
EDIT: Also check for LOS.
What dish to buy for eastern arc?
Hopper instal ?
