222k receiver with a 1K.4 EA Dish. 1 HD TV at receiver location and 2 tv2's mirrored.
Problem:
TV2 from the home distribution port has a rolling picture similar to an old v-hold adjustment. The TV1 output from the same home distribution port comes in crystal clear with absolutely no problems.A direct line from the receiver to the Digital television will work for both tv1 and tv2 from the home distribution.
What has been Done:
222k receiver with a 1K.4 EA Dish. All of the cabling, components (ground blocks, diplexers,etc.) have been replaced new. Outlets have been tested good. The receiver was replaced, and the customer started having this problem when she upgraded from a 322 which had no problems. Direct lines have been run from the back of the receiver and switched the home distribution connection was changed from whole home to direct line. Also tried other temporary televisions and different electrical outlets. The problem stays consistent and is the worse from one TV in particular.
I am at a loss and stumped any help iis greatly appreciated!!!!!
Problem:
What has been Done:
