It would work like on demand does. Dish would keep the content on their end.
I give up - you don't get my point.
Dish records all the channels contents and you have access to them anytime. Dish figures out a way around getting into trouble for doing so.
What was the outcome, if there was one, of Cablevision's "cloud DVR" system ? Was it ruled to be allowable ?...or just hires more lawyers...
The OS doesn't know nor care what "type" the hard drive is. It still communicates through the SATA bus.Everything I'm read about it says that the OS would have to be changed to use SSD's...
They're going to announce that you can have Hopper and ViPxxx in the same house (and same account).
Incorrect answer I did my research on it. The SSD isn't the run the same way as an HDD. They can't do the linux clean of the space that is marked as unused now. It can no longer reformat the partition or maybe do the Fsck.The OS doesn't know nor care what "type" the hard drive is. It still communicates through the SATA bus.
"You are going to have to post something to back that up my friend"Incorrect answer I did my research on it. The SSD isn't the run the same way as an HDD. They can't do the linux clean of the space that is marked as unused now. It can no longer reformat the partition or maybe do the Fsck.
Switching to ext4 is a non-issue as ext4 is backwards-compatible with ext3. ext4 is primarily just an enhancement of ext3 with journaling support added. Now, Dish may use an older kernel that doesn't support TRIM. Being a "closed" system, not staying up-to-date with kernel development is generally a non-issue - it works for them.I believe Dish uses EXT3.
Consider this Dish new receivers are super as they offer true UHD or 4K.
Dish will have true 24/7 UHD programs plus pay per movies in UHD.
Dish also could team up with companys like sony to offer the new receivers with the purchase of an UHD Sony TV
2014 is the year of UHD.
If this is what Dish have up to then a $10.00 fee for HD makes sense.
or I maybe way off base.
I don't know, they've done TV & receiver deals in the past. You may be on to something they announce for late in the year.
I suspect UHD support may in and of itself allow for an additional fee.
