AJE is on transponder frequency 12152, which is typically the easiest to locate and the strongest transponder on Galaxy19.
Press TV is on transponder frequency 12053. This is not a weak transponder either, but it often can be peaked by slightly moving off G19 as their is some adjacent satellite interference. Try balancing your dish for peak and highest Signal Quality readings on all transponders. G19 can provide some challenges if the system is optimized on only one or two transponders.
Check the LNBF skew and sliding the LNBF in or away from the reflector. Often you can peak and balance the SQ on all transponders with the LNBF placement.
