I live in Florida and interested in receiveing Hispasat C/D. My equipment is fortec lifetime ultra receiver, I have a couple of DN and DTV dishes and a 36" dish that I assume was used for primestar. I have several LNBs good for DN and DTV, my 36" dish has an LNB model number:NJR2112F, I has two cable connections a horiz and a vert. What do I need to access hispasat? I'm assuming my 36" dish and will any of the LNBs that I have work? If not what do I need exactly. Also is there a specific distance that an LNB must be located from the dish surface? Thanks in advance for any help
Hello and welcome to the SatelliteGuys.US FTA forum
Your 36" dish will work fine but (IMO) you would be best with a new LNBF. The below LNBF will bolt to your feed horn and its a great quality / low noise value. I think you would have great success with it! And unlike the LNBF you have right now it has one output that will work with both H and V signals. I live way up here in MN. And I pick up most of the channels form these satellites. I also use an Invacom LNBF!
