Help with setup
neoflex
Installed a new satellite slimline dish with the 5-LNB and putting in the new HR 21 700 HD DVR.
I have great signal strength on the 119 (90%), but nothing on the 110 (etc.103). SO not sure if there is a setup error, or do I need to continue to play around wtiht the dish pointing.
THanks
Ok...still figuring this out. Did tweak the dish, and now I am getting the 110 and 119, but nothing on the 101 for satellite strength.
Any suggestions....as wondering if this is still a dish pointing issue.?
You should be using the 101 to peak the dish in the beginning and go from there.
If you have the 110 and 119, it's probably a tilt issue.
I always start with the 101.
Jimbo
I'm guessing you are pointing at 110 and not 101.
Jimbo
I would also triple check that the mast is plumb, and your presets are correct. I do agree that if the mast is plumb, it is probably a tilt issue.
Good point,
I forgot to mention that, the mast needs to be plumb before anything else is done or all your other adjustments will be off.
Jimbo
Are there retail locations to "play" with an working HR20 or HR21?
Low audio on HR21
