Calling the remote guru (Edmund) to the white courtesy phone.![]()
quick and fast way to do it would be this...
Turn on your TV.
on the DIRECTV remote.
Slide your mode to TV
press and hold SELECT and MUTE button at the same time til you get 2 flash of light...
press 991
flashes 2
press 1 again
and use the channel UP button til your TV turns off,
once it turns off,
press SELECT and it will flash 2 times
and press the PWR button and the TV should come back on.
THIS will do a AUTO code search... and find what you need to run the tv. make sure your volume works and such
after that is completed, you can do this to get your TV INPUT to work too...
TV mode again
press SELECT and MUTE again til it flashes 2 times
press 9-6-0
and select,
press TV INPUT to verify the TV INPUT changes. if not, then your tv didnt get coded or didnt have a code for this function.
Turn on your TV.
press 991
flashes 2
press 1 again
once it turns off,
TV mode again
press 9-6-0
and select,
