I would go to the dish signal screen (menu,6,1,1) select the 61.5 satellite, select dish 300, type in your zip code and it will give you your elevation and azimuth for your location. Then use a compass to see where your dish needs to be pointed. Adjust the elevation on your dish using the scale and fine tune your signal using the dish signal screen. One tip that may help you; get 2 seperate phones, call the other phone and place it by your tv speaker. Now you can listen on the other phone for the signal tone. I found this is alot easier then yelling at my wife and getting mad! A satellite signal meter makes this tip pointless.
Good luck,
MountainMan
