HELP with install
tjwc1
galiano bc
Hello all, This is my first ever sat system and I am in need of some help. It is a bell system with 6131 HD recever. the dis cam with 2 LMB's a SW44 switch and a power box. The instructions that came with it only show hooking up more than one dish or recivers. I tried using the switch with no luck so i ran one coax cable direct direct from the dish to the reciver and it works but I have no HD. Can some one tell or show me a diagram on how to hook this up.? Thanks TJ
Thanks i will try that in the morning, one more question will the switch work if it is not grounded? i havent grounded it cause I have to run such a distance to get to the ground rod on the house.
Thanks again for your help
TJ.
Set the SKEW on the Dish first.
Aim by using a line from 91 LNBF to the Receiver ONLY. No Switch nothing, just a direct line.
When you have 91 Peaked, add the second LNBF and Switch.
Ensure that Port #1 on the Output Side of the SW44 has the Power inserter on it.
Run Check Switch (Menu 6, 1, 1.)
Enjoy.
Value for my 3 yr-old Starchoice 505HD receiver?
Shaw Direct HDPVR 630
