Help with adding another receiver...
dbinaz
7
Laveen, AZ
I have a Dish 1000. 2 runs going to my structured wiring can from it feeding 2 dual tuner receivers. I want to add another single tuner HD receiver. How do I go about this? Another run from dish or can I use a DP34/44 in my can?
Thanks,
Derek
You will need a DPP44 switch to feed 3 receivers. Run 3 (119, 110, 129) cables from the dishes to the switch and then from the switch feed the 3 receivers.
So are you saying I am currently not receiving all those sats right now cause I only have 2 lines run from the dish? Or the built-in switch in the dish is taking care of that right now?
The DPP Twin has a satellite input and the switch is built in. So with a DPP Twin you can have 3 satellite locations and feed a dual or single tuner with one cable.
Worst call center experiance ever. My letter to CEO
E-Bills from Dish?
