My system:
A Slimline 3LNB dish with two lines coming into the house from the dish. One line is connected directly to a HD box the other line is connected to a non-hd box.
Problem:
I purchased a multiswitch hoping to add a third box without having to run more cables from the dish into the house. When I connected the two lines coming into the house to the first 18v input and the second 13v input and then connected the other three lines to the first three "outs" on the multi-switch, the HD box no longer has HD programs (when I select an HD channel the box says searching for satellite signal) and some of the regular channels that I am supposed to be getting are no longer there. The missing channels is a problem on all of the connected TVs.
Can any one help? Why do I no longer get HD programming? Why are channels missing from my package? How can I get all the boxes to opperate as they are supposed to using this Zinwell Wide-band 6x8 multi-switch? Is it possible to do what I'm trying to do —simply add a third tv using the multi-switch?
Problem:
