Hi Guys,
I gave up on the little 18x20" dish and got a larger world direct dish with 1 linear, and 1 circular lnb.
I am having trouble getting any kind of signal at all though.
the dish just arrived today, and i spent a couple hours trying to get signal, but have had no luck.
Here is what I have:
World Direct dish, mounted on flat surface, using a tripod.
the dish has 1 circular, and 1 linear lnb (unhooked the circular one)
My location is Aberdeen, Washington 98520
Clear line of site
I have looked online and found the satellite co-ordinates:
Full-screen
Address: Aberdeen, Washington
Latitude: 46.9754°
Longitude: -123.8157°
Satellite: 101.0W AMC 2, 4 | DirecTV 8
Elevation: 31.6°
Azimuth (true): 150.1°
Azimuth (magn.): 132.8°
I have tried pointing in that direction using a compass, but cannot pick up anything at all: 0 signal, 0 strength
I have tried setting up the Manhattan Skyline 1000 receiver as per the directions from Adventist Satellite website:
[SIZE=+2]FTA Satellite Receiver Programming[/SIZE] This guide will assist in programming your receiver to enable reception of 3ABN Television, 3ABN Latino, 3ABN Radio, RADIO 74, ATN HOPE, ATN Business, LifeTalk Radio, LLBN and many other Free To Air ( FTA ) broadcasters.
Before attempting to program new channels it may be necessary to make adjustments to the dish and/or LNB to obtain a strong signal that reflects good signal and quality levels. Poor signal quality will affect the ability to program and properly receive additional channels.
[SIZE=+2]Adding New Transponder Information[/SIZE]
[SIZE=+1]On Satellite AMC-4 (GE-4)[/SIZE] 1. Using the remote control, press the [SIZE=+1]MENU[/SIZE] key, then press the right [SIZE=+1]VOL[/SIZE] key, the INSTALL box will highlight.
2. Press the down [SIZE=+1]CH[/SIZE] key once, and highlight 2. CHANNEL SEARCH. Now press the [SIZE=+1]OK[/SIZE] key, and the CHANNEL SEARCH window will open.
3. Press the down [SIZE=+1]CH[/SIZE] key 4 times until TP DATA is highlighted, then press the [SIZE=+1]OK[/SIZE] key. A TRANSPONDER DATA window will appear, on the right, with TP1xxxxxx) at the top in yellow.
4. Press the right [SIZE=+1]VOL[/SIZE] key until TP(x): USER DEFINED appears in yellow.
5. Press the down [SIZE=+1]CH[/SIZE] key once, and highlight FREQ. Enter the frequency (i.e. [SIZE=+1]11983 [/SIZE]for ATN / LifeTalk)in the box.
6. Press the down [SIZE=+1]CH[/SIZE] key twice, and highlight Symbol Rate (S/R). Type the Symbol rate (i.e. [SIZE=+1]05900 [/SIZE]for ATN / LifeTalk).
7. Skip to step 8 if the Polarization is correct ( Horizontal for all of the Adventist channels). If it is not correct, press the Down [SIZE=+1]CH [/SIZE]key to highlight POLARIZATION and change.
8. It will take up to 15 seconds for the SIGNAL and QUALITY bars to turn green. Press the down [SIZE=+1]CH[/SIZE] key several times until STORE is highlighted in yellow. Press the [SIZE=+1]OK[/SIZE] key once and the TRANSPONDER DATA window will disappear.
9. Press the down [SIZE=+1]CH[/SIZE] key twice and highlight START. Press the [SIZE=+1]OK[/SIZE] key once and the receiver will automatically store the new channel(s), power off and repower.
Repeat these steps for each transponder that is to be programmed.
But still nothing.
Would someone have the patience to teach me what i'm doing wrong?
I would very much appreciate any help you would have to offer.
Thank you very much
Shnippy
Clear line of site
Latitude: 46.9754°
Elevation: 31.6°
But still nothing.
Thank you very much
Shnippy
