Hi, I just got my 505 starchoice receiver, and I was able to find and point to the Anik F1 satellite, I get picture and sound on the 200 channel, but I can't seem to find the Anik F2 sat!
I'm in Mexico city and I'm using two 90Cm antennas.
When you go to options, system setting, installation settings, or something like that, the signal meter is dependent on what channel are you at?
I got a 90 quality signal and if I input the provider ID 4128 I get satellite name A4, but that's for Anik F1, what name should it be for Anik F2? and it's the same provider number?
According to my position I should use an Azimuth of 202.88° and an elevation of 65° to get Anik F1, and I think I got that, I got above 80 quality.
And I should use an Azimuth of 212° and an elevation of 63° to get Anik F2. So all I should is place the second antenna as the first one, and then move 10 degrees to the right and 2 degress down, but ther all I get is 20 in signal quality!
I really have no idea how to get the second sat! I have tried moving the antena around that area and I get no more than 21 in signal quality!
Do I need to do something special with the receiver? Are the two satellites that close that you just have to move the antenna very little? How will I know if I'm getting F2?
Thanks in advanced for any help you can spare.
