Resolution, solution or something like that.
To All,
Cutting to the chase the problem is resolved, but as you will discover the resolution is as strange and mysterious as was the problem. This is going to take a bit of explaining so hang in there with me.
.....status as of this afternoon.
As of 3:30 today there still was no audio from Ch 74 UHD or Ch 11.1 OTA CBS HD Dallas plus Ch. 11 CBS HD (DTV) (no previous problems).
......a New Denon AVR 987 (2807) is Purchased
To prove to DTV that my Denon AVR was not the problem I went to CC, and after explaining the situation in detail purchased a new identical Denon AVR 987.
......the coxial factor
In the mean time I disconnected the twin sat coxial cables and single OTA coxial from the Monster 3600 MkII then reconnected them directly to the DTV HR20-700 (bypassed DTV filters also).
....the Monster factor
I took a brief break and looked over my emails whereupon I discovered a reply from another forum telling me that my Monster power center was only rated for 2.5GHZ and the new DTV spec. for coxial cabling is now 3.0 GHZ. A quick call to Monster confirmed this distressing fact. Additional quick research revealed that their is no major AV power protection device on the retail market meeting the 3.0 GHZ specification.!!!
....the "new" Denon 987 goes online
Next, I moved all necessary cabling from the existing Denon AVR to the "new" identical twin Denon AVR. Powered her up and bigger than life there was DD in all its glory on Channels 74, 11.1 and 11! I immediately said to myself that it was my original Denon's fault all along.
.....the room is spinning, my mind is whirling
Here is where we go into the twilight zone again! I disconnect the new Denon AVR and re-install the original Denon AVR. Likewise all coxials are returned to their original positions (routed through the Monster power center and through the DTV filters) and of course reconnect to the HR20-700.
......I pick up my Harman Kardon TC30 Remote Control
The Denon AVR, TV and DTV HR20 all come to life.......Channel 74 appears and................it is in Dolbly Digital! A quick switch to 11 and 11.1 reveals that all three work flawlessly.
.......So what was the real cause of the problem?
I don't have a clue as to the cause of the problem
.......So what action solved the problem?
I don't have a clue as the the solution either. All I know is that it works.
Postscript
I cancelled the late afternoon DTV service call. Returned the "new" Denon AVR along with a new multi-switch that I purchased just in case it was needed. Went home and tried to explain it all to my bride of 28 years after which she took me out for a nice supper at our local diner.
That is it friends, I really don't know what else I can see but simply that all is back to normal. If there is such a thing as normal for a DTV Customer!
Comments welcomed.
I sincerely thank you all for the help and support.
L.Patrick
