The good thing about the Cband dishes is that the two adjustments were reasonably independent.
On the H-H motors, they interact.
The only way to change your Ku declination to get it right (assuming you are targeting your southern bird), requires you to change the motors elevation, then do an opposite direction adjustment of the elevation on the back of the dish, to bring it back onto the satellite.
More I think about it, that's what you do on a C-band dish, too
At lest there, you can dial in declination if you need it, often by using washers to shim the mount.
If you follow the printed literature, and leave the motor alone, but adjust the dish's elevation, you are doing two things:
. adjusting the elevation of your beam
. adjusting your declination
That can't be good, and may be a reason so many people have trouble finding the arc.
Well, I think both prime focus and offsets use declination and elevation settings independent of each other, it just seems easier to setup a big dish with less fuss, but then again, I never did one with a hh motor, just actuator so arc travel was less. I wonder if its recommended to set the motor elevation and leave it and play with the declination because the motor elevation bracket scales are relatively accurate compared to the declination scales, some of the dishes don't even have a scale. Anyway, kiind of interesting, any of the satellite theory books I have, without exception state, set the declination and leave it alone except for in the end of the alignment process, when minute adjustments might be needed between the two elevations.
