So you can get your system up and running to just enjoy viewing programming for a while .....
Perform a Factory Reset on the receiver.
Remove the dish from the Motor and mount directly on the mast.
Connect the L output of the QPH-031 LNBF directly to the the receiver.
Set the receiver and a small TV next to the dish.
Set up your Viewsat receiver to these settings in the Antenna Setup screen:
- Satellite - Intelsat 5  (not 5/C)
- LNB Type - STANDARD
- LNB Frequency - 10750
- 22KHz - OFF
- TP Frequency - 12177
- Search Option - FTA
- DiSEqC 1.0 - NONE
- Motor - NONE
Dish information:
- Standing in front of the dish looking into the dish and at the back of the LNBF, rotate the LNBF Counter Clockwise (left) +24 degrees.
- With the dish mounted on a perfectly plum post, set the dish elevation angle to 37 degrees using the straight piece of metal visible through the elevation scale to the left side of the elevation locking nut.
- Take a compass reading near the dish, but stay at least 4 or 5 feet away from the dish so the metal of the reflector does not affect the magnetic reading. With the arrow aimed directly at North, reference 225 degrees (SW) and identify a landmark like a telephone pole or building near the horizon (as far away as possible) that lines up with this reading. Aim the LNBF arm at this landmark. This is a reference point for the aiming process.
Now reference the TV screen and make slow, sweeping movements 125 degrees to the east of the landmark to 15 degrees to the west of the landmark. If you see the signal level jump up, but not the quality, you are on a satellite, but not the correct one. If no Signal Quality reading is found, increase the elevation by one degree and slowly sweep the small area of the horizon again. Repeat this process, increasing or decreasing the elevation one degree at a time until the Signal Quality reading indicates the highest percentage.
Once a quality signal is indicated and peaked, perform a Blind Scan.
When the Blind Scan is completed ..... Save, Exit and  Enjoy!
