It would be a good idea to use a sat finder, preferably one that can be set the ber to log format for fine tuning...........ka band requires precise pointing..........get your mast level and plumb, be sure you catch a truss line with your center holes......this is not optional! Also be sure you use both monopoles for added support........tighten collar bolts enough to take the play out of it but loose enough to still easily turn, set elevation, and tighten inside nut on elevation adjustment, leave two outside nuts loose.....rotate back and forth to find your high point, and then lock down collar bolts......turn elevation adjustment on dither with 1/2 inch nutdriver to obtain highest strength, once you peak, set tick dial to zero and then make two full rotations counter clockwise.....record what your signal is......then begin rotating dial clockwise, carefully tracking number of turns down to the tenth, passing your original start point and stopping when you get to exact low point you hit when making the first two rotations counter clockwise, now take the number of turns it required to reach this point (for example maybe you went two to the left, and then had to go 5 to the right to get to the same low point, 5 would be the number we want) now divide that number in half and after setting dial back to zero again, turn counter clockwise until you get to that half number of rations, 2 1/2 by my example........lock down elevation bolts....then follow same process for azimuth after loosing two nuts under front of dither mechanism........hope this helps.........skew can usually be preset, but may need to adjust to peak out 119.....
