I have three dish units in my house (two Dp301-10's, one 3900) with a sw44 switch and recently one of the dp301-10's has started to act up and I can't seem to fix it. The dp301-10's does the following:
When I plug it in and put the card in, it starts it's "aquiring satellite signal thing" and all it will do is continually try to find a transponder on satellite 'default'. This goes on forever without it ever getting past progress status of 0 of 5. It will just continually cycle through the transponders.
If I run a check switch, it goes through the 38 tests but it always says at the end 'Installed Switch: Unknown' and doesn't pick up any satellites. The other recievers in the house are fine, and this one was fine prior to two or three days ago when it just suddenly started this problem.
Any idea how to fix this guys? I would call Dish but I have a feeling they would just give me the typical run-around and I would end up posting here anyways.
Thanks!
edit
*grumbles* I meant to post this in the tech forum, is there any way to move it? Thanks again!
Thanks!
edit
