HDTV broke, need to reset 211
BirdFLU
PDX
BooHoo for me, my only HDTV just died. I hooked my 211 receiver back up to a standard TV, but the 211 is still set for HD 16x9. Since I can't see the picture correctly, I can't change the settings. Factory reset doesn't change the settings.
I know if I press MENU then 6 that gets me into system setup. What are the next key presses to change the 211 back to a standard TV?
(The manual is no help and neither is DISH web site)
Thanks for any help!
You can connect the 211 to the TV via the composite (Yellow) video output using 1 of the component cables and change the settings. The original 811s shipped at 720 p and that is how I sorted it out.
On my 622, the keystrokes are Menu, 6, 8, <, <, ^, >, >, Select. The number of ^ varies depending on whether the box is at 720 or 1080. For starters, you'd want to set the box's resolution to 480i. The TV will show a picture at 16x9 or 4x3, but the resolution is the problem.
Miner
Dish 222: Only mono sound for TV2
Dish Remote DVR Access iPhone APP
