Does HD place a higher burden on a cable than SD due to its greater data transmission ? I have installed a 211k in an existing cottage which is wired with old CATV cable. The HD on sat. 110 is 10 to 15 points lower on the DISH signal strength meter than the 119 SD. I know RG 6 should be used. But I was curious from a technical issue whether HD data transmission over the old cable is accounting for the lower signal strength.
The cottage next door has RG 6 and the 110 signal strength is 10 to 15 points higher. Bob
