HD LNB's and Switches.....
PhoneLine
9
Hey guys.
I have a question regarding a upgrade I am considering. I currently have a dish 522 and 301. I have these hooked up via a DP34 switch to 119, 110 and 61.5 with Dish Pro LNB's.
I am considering getting a HD receiver in place of the 522 and just plan to leave the 301 alone as its not connected to a HD set anyways.
Will the HD box work with my current LNB's and DP34 or does something else need to be changed? Plan on doing some work to hide the wires and switch and want to get the receiver after the semi-construction is done, and want to know if it wll be as easy as just switching the 522 for the HD box.
Thanks for any info.
James
Current 2 coax to 522 will works for 622 - one little concern, if you will need something from 129W; then will replace the DP34 to DPP44, add new LNBF ( or get D1000.2).
I'm in Brooklyn, NY, so think I just need 61.5? Would I need to access 129 also?
Thank you for the info.
Cable company cutting lines - legality issues?
PPV coupon and HD question?
