You need to make sure the installation order lists SWM.
From what I've seen is don't trust what the DirecTV CSR's say about this, you need to call the company contracted with that does the installs and verify with them exactly what's on the order they received.
How do you find out who the company contracted is?
Chances are high that it will be a SWM with 5 tuners, but not always. D* has told HSP (Install companies) that if the customer requests SWM with less than 6 Tuners to charge $129 for the SWM LNB and components. A lot of it also depends on what type of receivers the HSP has in stock at the time of the install.
DirecTV's latest e-mail tells HSPs that any NEW install with five or more tuners (i.e. one that requires a multiswitch) should always use an SWM dish. Whether they have any way of enforcing this I do not know.Chances are high that it will be a SWM with 5 tuners, but not always. D* has told HSP (Install companies) that if the customer requests SWM with less than 6 Tuners to charge $129 for the SWM LNB and components. A lot of it also depends on what type of receivers the HSP has in stock at the time of the install.
