Just to make sure that anyone reading this who is confused about the audio differences I will explain them below.
The current surround formats that are most common today are Dolby Digital 5.1 and DTS 5.1 surround sound. Both formats are compressed audio while DTS uses "less" compression compared to Dolby Digital. Dolby Digital 5.1 is on nearly every current DVD movie and is also used widely on many cable channels both SD and HD channels. Some examples would be SD HBO, ESPN HD, ABC HD etc. DTS 5.1 is only on DVD movies for the mass markets.
The most common way to get both Dolby Digital and DTS 5.1 surround is via either a coax digital audio connection and/or an optical digital audio connection. The player or the receiver "must" be able to decode both Dolby Digital and DTS surround sound respectively. For example most cable boxes "cannot" decode Dolby Digital 5.1 surround sound so your receiver must be able to decode the AC3 (aka Dolby Digital) stream sent from your cable box.
Many DVD players available today can decode both Dolby Digital and DTS 5.1 surround sound and send a PCM signal that your surround receiver can decode.
Dolby Digital and DTS surround sound can also work via 5.1, 6.1 and 7.1 analog audio inputs as well.
Now onto the HD audio stuff. Right now the most common surround format for HD audio that both HD DVD and Blu-Ray HD supports is Dolby TrueHD.
Dolby TrueHD is fully lossless and is bit for bit identical to the original studio master. The problem is that the normal coax and optical audio connections just don't have the bandwidth to pass this full lossless signal.
So as of now the only two ways that are available in mass market products that have the bandwidth to decode Dolby TrueHD are analog audio connections and HDMI. Now nearly all HD movie players can downconvert a Dolby TrueHD signal and send it out either PCM or Bitstream over coax and optical connections but this is again very lossy audio compared to the original TrueHD signal.
Everything above also applies to the DTS HD audio standard as well. Most HD movie players can decode both Dolby and DTS HD audio formats and send them bit for bit over an analog audio connection and/or an HDMI connection.
So simply put to get the full lossless HD audio experience your surround receiver must have either an analog audio input or an HDMI input. Beyond this requirement your HD movie player "must also" have one of these two connections as well.
So say your surround receiver has 7.1 channel analog audio inputs "but" it doesn't have an HDMI input. Well in this case buying a PS3 "WILL NOT" get you this lossless HD audio as the PS3 doesn't have an analog audio output . Because the PS3 only has an HDMI output your surround receiver "must" have an HDMI input to fully support lossless HD audio.
Now again remember that as long as your receiver has a coax and/or optical audio connection nearly all HD movie players will still be able to provide 5.1 surround sound at the least but it again will be lossy and very near DVD type surround sound.
I hope this post can help avoid some of the confusion I believe many readers may have regarding these new audio formats.
