72 is back here as well. Nice that it was a temporary glitch but would be interesting to know what happened. What is the over/under for when the compensation thread starts?
Wonder if someone flipped the wrong switch. Here in went out at almost exactly 8PM EDT.
You'll both have to answer to the Kitty Cat Commission for your transgressions!
72 is back here as well. Nice that it was a temporary glitch but would be interesting to know what happened. What is the over/under for when the compensation thread starts?![]()
I don't have my signal code cheat sheet here, but if I remember right, the first digit being a 1 says the receiver is not talking to the dish antenna, which would surprise me.
I've always wondered about this. Why does the SD work when HD doesn't? Let's have it the other way around....then most of us wouldn't even notice!I'm on eastern arc and I had this happen around 11:00am central time this morning and the receiver defaulted to the SD version of the HD channel I was listening to/watching , while I got ready for work. I put up the guide and selected the hd version of the same channel and it worked again. Tonight it hit again around 7:00pm central time , same error code 11-11-11 and the channel again defaulted to the sd version of the hd channel, on 61.5 sat. Seems to have only affected the hd channels on 72.7 sat. My locals are on 61.5 so no loss on those channels.
I've always wondered about this. Why does the SD work when HD doesn't? Let's have it the other way around....then most of us wouldn't even notice!![]()
Yes often the SD signal is from a different satellite.
I can't speak for eastern arc, but for western arc, it's usually that the customer is not getting the 129 sat. In general, with the WA folks, if they get the HD revert to SD, and they were to check Menu-6-1-3, on line G, they'd see 119/110/129, and 129 would be red, where 119 and 110 would be green.
I need to look more at the EA to see how it's laid out, since nearly all of the SD and HD programming is on 2 sats (61.5 and 72) versus the WA where most of the HD stuff is on 129.
