Tampa8 said:Roku does 5.1 Dolby Digital surround sound. It's a pass through, meaning it will pass the digital information on. You just need a Dolby digital receiver. I have an older model and even it does it. If the source is in Dolby digital, the sound will be.
Is that a question?For any of you Roku guys and gals who may not have been aware, google "hidden Roku channels" and "private Roku channels" and you'll find a couple dozen more that you might not have known about?
also the prider has to support dd as well. I had the orginal box when netflix was only on it and it had it then
Uh...Really? I have the Roku hooked up to my Yamaha digital receiver via optical output and never once had it detect anything other than PCM. I have checked the settings on both the receiver and box as well as switch optical jacks with the 622 to verify the receiver is seeing DD signals properly. Using HBO Go, Netflix (while I had it), Epix movie channels I have yet to see a DD program via Roku. The PCM carries great Dolby surround, but no DD.Roku does 5.1 Dolby Digital surround sound. It's a pass through, meaning it will pass the digital information on. You just need a Dolby digital receiver. I have an older model and even it does it. If the source is in Dolby digital, the sound will be.
As is always the case, your comments about HBO Go and Dish are incorrect and/or indecipherable.It may have not occurred to anyone but certain stored series are not available on the Roku for HBO. If you have a Dish subscription, and a HDTV then HBO-GO provides all of its programming. Also I noted that sometime last week late at night, the full HBO series of 36 episodes of Deadwood magically re-appeared after showing just 10.
You can get ALL, not just some, HBO content on Roku, if you have an HBO subscription with a carrier that supports it, and add the HBO GO channel.ok so you get some hbo content on roku?? doea this apply to boxee as well.
Yes. HBO OD on Dish receivers has a very limited selection. Plus, the interface is so bad as to be almost unusable.I watched all 36 episodes of Deadwood on the Roku not two weeks ago. It's HBO OD on the Dish Network boxes that had only 10 episodes.
Sorry Dan, I don't know the answer to your question
The carrier's logic, such as DirecTV's, is that if you were able to watch unlimited HBO programming on your TV without a DirecTV receiver, you just might choose not to have a DirecTV receiver in that room, depriving them of an extra receiver fee. It really seems like something Dish would do, not DirecTV.I beluve I read where time warner is blasting providers that are blocking the roku acess and other box acess to force customers to get their box. doesn't make sence since hbo go is different that hbo od and the live channels
