Hello All,
I am new to the world of FTA and am having trouble setting up my Captive works FTA system. I was referred to these forums by the company I purchased the system from.
First here is my set-up info.
Receiver: Captive Works CW-600s
Dish: 76cm oval
LNB: Invacom quad polar with 40mm horn
Coolsat 4x1 DiSEqc 1.2 switch
Rotor Sg-2100
I have not done any updates to the software. Everything is as it was when I received the system,
My Location Zip 40204
Long 85.7324
Lat: 38.2296
Here is my problem.
I cannot find any satellites.
Here is what i have done so far.
Day 1:
Mounted pole vertical and plumbed.
Mounted SG-2100 on pole facing south. ( true south not magnetic)
Mounted Dish on rotor
Ran coax ( which is new and has been tested for continuity) from LNB to Coolsat 4x1 DiSEqc 1.2 switch....LNB 1 to switch position 1, LNB 2 to switch position 2 etc.
I set the dish declination angle to 24 ( i have also tried 30)and the elevation to 52. I moved the dish to where 101 AMC 4 should be and got nothing.
I have tried just about every combination i can think of and I still get nothing.
Except one time i did lock onto what i thought was AMC4..it gave me a strength of 90 and a quality of 44..i did a channel search and got nothing. I did a TP search and the front of the receiver displayed FALI.
Day 2:
I removed the dish from the motor and mounted it directly on the pole and pointed it at 191.7 AZ and 55.95 Elevation according to the reading my Sat finder program gave me to find AMC4. I would get a 66 on the strength meter and 0 on the quality.
Day 3:
I removed the dish completely from the pole...brought it into my house...hooked it up and guess what...I am still getting a strength reading of 60-70 %.
I have bypassed the motor as well as the DiSEqC switch and I still get those strength readings. I have plugged the LNB directly into the receiver and still 60-70% strength 0% quality. I am stumped...any help would be appreciated.
Day 4:
I typed this request for help
Thanks,
Bret
Dish: 76cm oval
Rotor Sg-2100
Long 85.7324
Lat: 38.2296
Here is my problem.
Day 1:
Day 2:
Day 3:
Day 4:
Thanks,
Bret
