Hi,
I have dish and the picture quality just sucks, not really sure why. I am looking to moving to Direct TV when i upgrade to get HD.
Can anyone help me with the following. i am curently using one dish DVR to feed two rooms, However we have the unit set on single viewer, so both rooms have the same output.
With the HD box can i feed my main tv with HDMI and then using an RF converter feel the output of one of the other connections either s-Vid or component to another room? I did a search on the forum i fount two posts, the first said it will work fine the other said you will have to set all the outputs to 480i to get it to work. i dont want that to be the case as changing the settings back and forth would kind of suck.
Thanks for the help. (if it is possible to do the rf modulator route. can any of you recomend a inexpensive model)
