Hard Drive Failure?
Rey
@ your service
27,003
585
Florida
i think i'm experiencing hard drive failure. the windows stop error i'm getting is 0x000000F4. I was wondering what software you guys recommend for me to backup and restore to a new Hard Drive? thanks for any help.
Which windows do you have? I would back up the computer right away if you suspect an HD problem. You could come in to a completely failed system soon. If you have XP backup will backup the entire drive. If you have Vista there is a complete PC backup which images the drive or there is an option to backup just files.
mike, i have winxp pro sp2.
Does this happen when you resume from standby or some other time? If so this might help...
SYMPTOMS
A computer that is running Microsoft Windows XP or a later operating system stops responding during resume from standby, and you receive the following KERNEL_DATA_INPAGE_ERROR stop error message:
0x0000007a (e163a3e4,c000000e,bf8e9313,0697f860)
or
0x000000F4 (0x00000003, Parameter2, Parameter3, Parameter4)
Note Parameter2, Parameter3, and Parameter4 in the stop error may vary.
This problem occurs on a computer in which Windows XP or a later operating system is installed on a hard disk that is configured as a subordinate and no other device is connected to the same IDE controller channel (primary or secondary).
Back to the top
CAUSE
This behavior may occur when you use Windows XP or a later operating system with some motherboards. Microsoft is researching this problem and will post more information in this article when the information becomes available.
Back to the top
RESOLUTION
To resolve this behavior, use one of the following methods:• For Parallel Advanced Technology Attachment (PATA) hard disks, configure your disk drive as master only. For Serial Advanced Technology Attachment (SATA) hard disks, connect the hard disk cable to a master channel SATA connector on the motherboard.
• Connect another device as a master, such as another disk drive or a CD drive or DVD drive.
• Change your PATA and SATA IDE cable even if the cable does not appear worn.
• Install Windows on a new hard disk because it is possible that your hard disk or your Windows installation may be corrupted.
Back to the top
MORE INFORMATION
Steps to reproduce the behavior
1. For PATA hard disks, set the hard disk jumper to slave mode. For SATA hard disks, connect the hard disk cable to a slave channel SATA connector on the motherboard.
2. In BIOS power management, set BIOS to S1 or S3 (STR).
3. Install Windows XP Professional with Service Pack 1 or Service Pack 2.
4. Restart the computer.
5. Set the computer to Standby.
6. Try to resume the system. The system stops responding.
SYMPTOMS
or
Back to the top
CAUSE
Back to the top
RESOLUTION
Back to the top
MORE INFORMATION
Hey i'm sorry i never noticed your response. i appreciate the help. i already had figured it out and downloaded a patch from the microsoft website. thanks again! i did perform some of the tasks you posted :up
IE 9
Intel Set to Phase Out i7 940 & 965 Chips
