I'm trying to add Ku to a 7.5' mesh dish with only a C-Band feedhorn. I tried using a DirecTV LNBf but was told that these are cicular polarized and not linear polarized. So I purchased a 0.3Ku "electronic" LNBf.
Even with a LINEAR 0.3Ku I'm not getting anything from G10R. I get a signal strenght of 94 out of 100. But no QUALITY reading at all.
Can a LNBf be simply mounted next to the C-Band feedhorn? Is the focal point that critical if using an LNBf offset slightly from the center? My thinking is that using something meant for a 36 inch disk should surely work on a 7.5' dish by just being in the ball park.
Also, what is considered normal for polarity switching? My receiver does 14 volts and 18 volts (both with and without a resistor). Does this make a difference? Can physical position make this matter? I've tried several positions near the focal point and oriented the LNBf different directions. I get a solid tone on the Sat Finder; I just can't get a QUALITY reading.
(FYI, this same receiver on a C/Ku big dish feedhorn works as expected.)
