H20 output 480i and 1080i at same time?
blacksmoke
Does the H20 turn off the 480i composite output when the display resolution is switched to 720p or 1080i. I would like to connect it to two TVs one HD via a component cable, and the other a SD TV via composite.
The component and HDMI are hot at the same time. Not sure about composite.
All outputs are hot. I use the HDMI output for the Tv and send the composite signal to a modulator so that I can watch it over coax in another room.
I think it is, I have my main connection via HDMI to my plasma then I have a composite connection to a leapfrog going to a set in the kitchen, both work concurrently.
I connect the S-video to a Replay unit and HDMI to my TV. I'd bet that composite works the same as s-video.
How long will the lease model last?
Discovery HD 3D Glasses
